In the attached File is an example of a vector field visualization in SOP context.
It works fine, but I would like to make it easy to reuse and build a asset from the subnet subnetVolumeViz. I stumbled over some difficulties in the process.
How can I promote the parameter Plane Position of the encapsuled DOP Network ?
How can I access the sub network input #1 in the dopnet context ?
thanks for any advice
How to create an Asset from this Subnetwork
2973 4 1-
- dulo
- 383 posts
- dulo
- 383 posts
- dulo
- 383 posts
The gradient visualization looks quite nice in opengl, but if I try to render the lines in mantra I get those broad bands ( screenshot ).
How can I define the line thickness in mantra ?
Can mantra shade the lines as tubes without creating the geometry at sop level ? In Lightwave there was a parameter line thickness which could be set negative, which would result in those tubes ..
- graham
- 1914 posts
- dulo
- 383 posts
grahamWorked like a charm !!
You can add a ‘width’ point attribute to control the width of lines when rendered. I believe the default is something like 0.05.
![](/static/djangobb_forum/img/smilies/big_smile.png)
.., but I stumbled into to the next problem…
I animated the Viz Plane Position with two keyframes, but the values dont seem to get propagated. The parameter values change (the slider is moving) but the asset doesnt react. If I drag the slider manually everything works ..
in the asset I use relative references ( ch(“../../parmPlanePosition”) ) ..
.. and is it possible to smooth, or subdivide the streamers from the gradient visualization ? A simple subdivide node doesnt seem to work… but I just figured out that the convert to bezier node works .. which just leaves the problem with the keyframe updates ..
