Hi, I have a situation like this:
/obj/Geometry:
Sphere (or some dummy object)
xform (rotating arbitrarily)
/obj/AutoDopNetwork:
pyro node - (attributes) - Wind Tunnel
I want to get the direction the xform node is facing to be the wind tunnel direction for the pyro sim, but I'm getting stuck on how. In Maya, I would drop a locator parented under the node, offset it by one unit in X, and send its WorldPosition where I want it to go.
I imagine there's an elegant way to do this in Houdini, so what would you recommend?
Syntax / functions to get world x,y,z into an attribute?
2037 2 0- misterbk
- 20 posts
- misterbk
- 20 posts
So far I've tried these with no luck… I don't get errors or anything, but the channel stays at value ‘0’ even though ‘windtarget’ is transformed.
`chsop(“/obj/arrow_origin_ref/windtarget.position.x”)`
`origin(“”,“/obj/arrow_origin_ref/xform3”,“TX”)`
`vorigin(“”,“/obj/arrow_origin_ref/windtarget”).x`
Also tried ‘vtorigin’.
I'm guessing it doesn't work because these are sops and not objects. I'll try with a point and ‘prim’, see if that works better.
- misterbk
- 20 posts
BACKTICKS!
It was the backticks. It didn't like them.
For whoever cares, this worked great:
in /obj/my_geometry:
Grid (rows=1 cols=1)
group (group name = windtarget)
merge (merged with rest of geometery)
xform (animated rotating)
delete (delete nonselected, group ‘windtarget’)
Null (named ‘windtarget’)
In dopnet, in the pyro node:
X = prim(“/obj/arrow_origin_ref/windtarget”,0,“P”,0)
Y = prim(“/obj/arrow_origin_ref/windtarget”,0,“P”,1)
Z = prim(“/obj/arrow_origin_ref/windtarget”,0,“P”,2)
