When I create a FLIP object from the shelf tool, I cant resize my container.. I selected the container through autodop and then press Y.. but nothing happened.. when I right click the container I also cant resize it, the options do not show up.
I checked almost all nodes but I can see the parameter.. I can still work like this.. but I have the feeling Im wasting voxels..
Is anyone else able to resize the container when creating a FLIP object?
FLIP-object shelf tool, how do I resize container?
4583 8 1- vleermeneer
- 245 posts
- zdimaria
- 390 posts
- vleermeneer
- 245 posts
- zdimaria
- 390 posts
yeah you should see a considerable improvement. each and every voxel in all of your grids always has to be solved for. this takes lots of time and a considerable amount of ram. cutting down to only what you need is one of the best optimizations you can do imo. hopefully in 13 sesi will include some sort of spacial optimization, like sparse voxel octrees (crosses fingers)
- vleermeneer
- 245 posts
- zdimaria
- 390 posts
yes, but it is not in houdini. here is a good explanation http://www.youtube.com/watch?v=gNZtx3ijjpo&feature=plcp [youtube.com]
- vleermeneer
- 245 posts
- Solitude
- 373 posts
The flip solver already does an automatic resize container (you can see this if you look at say the surface field). Like zdimaria mentioned, all the empty voxels are still solved for, but the container size you are setting is basically the largest it can get. If you do limit the maximum size, then you will def stay under the mem limits. Even if you get one particle that freaks out and makes the fields resize to some large amount you can start to really slow down the sim. So only make its large as you need (depending the shot you're working on).
Ian Farnsworth
- zdimaria
- 390 posts
