If I scatter a bunch of points on a Font SOP, even if I pipe it through an extrude SOP, the points end up appearing in places where they shouldn't, as if there was geometry in places it is not seen.
For example if I use a C, there will be points “inside” the C….
Is there anything particular about the font SOP that causes this?
AC
Scatter points on Font SOP?
2112 2 1- rurik2000
- 87 posts
- jkunz07
- 76 posts
I think that happens because it's one big N-gon and the scatter sop works best with quads or tris. There's a few things I've done in the past to fix this -
triangulate 2d
divide sop with bricker polygons
extrude the faces slightly, isooffset (fog volume)
scattering points on the font after doing any of those should help a lot.
triangulate 2d
- rurik2000
- 87 posts
