UI_Queue::queueEvent event queue full
   16624   9   3
Hi there,
When copying and pasting a number of VOPs (around 12) that are all subnets containing a texture VOP and a few Parameter VOPs, I get these kinds of messages in the console:
UI_Queue::queueEvent event queue full. Events being dropped.
UI_Queue::queueEvent 316 events dropped.
UI_Queue::queueEvent 1 events dropped.
H6.1.208 on WIN-XP
Anyone seen this or know what's being reported? Bug?
Thanks,
Mark
You are no age between space
Try setting the environment variable HOUDINI_UI_QUEUE_SIZE to 20480 and then to higher values if you still get the problem.
Thanks Edward, I'll give it a try.
–Mark
Yep, that worked!
Thx Edward.
–Mark
I am running Windows 7 64.
Went into my windows env variables but I couldn’t find this. Is this found somewhere else?
thanks
Ryan Ackert
On Windows you'll have to create that variable yourself, just type it in to the User Env variables dialog. Set it to the value as appropriate…
PeteR B
Peter Bowmar
____________
I have also the same problem.
Could you please explane where I can adjust this.
NT_GeneratorThread::queueEvent event queue full. Event dropped
Ton
galinaton
Google windows 7 environment variables
http://www.itechtalk.com/thread3595.html [itechtalk.com]
Thanks,
Edward for your link. I have added an temp.
In many cases hitting the queue size limit is an indication of bad behaviour in Houdini, so it's usually worthwhile submitting it as a bug as well.
