hi,
i don’t know if there is a topic on this, but i don’t found..
i’m sorry , but i start with attribute.. perhaps my question is stupid, but..
i created a attribute area with measure node.
now, i obtain my 3 polygons with their area. i can see each in spreadsheet.
now i want delete the most larger area..
but i want use an expression for this, not enter a number… because i want use on many object.
i use a delete node, but how i can choose the most larger area?
please, tell me if it's understandable..
deleted the larger surface from $area..
1824 3 1- supermac
- 120 posts
- michaelwang
- 9 posts
maybe you can use attribPromote to promote your “area” attribute (Promote Method Maximum) to a detail attribute called “area_max”, then compare your “area” with “area_max”, something like this
if ($AREA == detail(“/obj/geo1/attribpromote1”, “area_max”, 0), 1, 0)
or you can promote your “area_max” from “Detail” to “Point” and then compare them directly.
hope that helps.
hope that helps.
- graham
- 1908 posts
- supermac
- 120 posts
