Protected vop type asset
   8345   3   1
I'd like to know if there's a plan to implement that and when would that be?
I'm referring to hide the code written in an asset created from “File - New Operator Type - VEX Builder Type” on a protected asset.
François
yep that's still in the plans, though I don't have an ETA for it.
That's fine actually I'm doing it with vop collapsed into a subnet then converted to a HDA because I have to use a ramp parameter and the other way didn't allow it.
Do you know if this mechanism already prevent the user from diving inside the HDA?
Yes, once it becomes an asset that is ‘copy protected’ you can't dive inside.
