I'm rendering some hair-like geometry. They are just 4 point open polygon curves copied to a sphere and they have a width attribute going from 0.006 at the root to 0.001 at the tip. They also have a black to white ramp applied via point attributes which then get referenced by a constant shader. The camera moves slowly.
When I render this setup, I get noise at the tips of each “hair”, which becomes even worse when applying DOF.
I tried rendering with super sample up to 7x7, jitter down to 0 and shading rate up to 2 in various combinations, but the noise is always there.
Here is a short closeup (tga) sequence of the noise with [people.freenet.de] and without [people.freenet.de] DOF.
Any ideas how to get rid of this?
Achim
Hair-like rendering / noise
6986 10 2- puma.snyder
- 121 posts
- Henster
- 196 posts
- puma.snyder
- 121 posts
- Henster
- 196 posts
Sorry, I've checked the images now… it sounded a little bit like a problem I had involving 2 sided shaders….. but its not.
The noise I can see is caused by each hair only being a pixels width which jumps obviously when moving from one location to the next?
My easy fix would be render off a seperate pass and blur it!
Or render at a higher res and shrink it hoping the resampling deals with it?
This hasn't helped has it….
H
H
Henster
- puma.snyder
- 121 posts
- thekenny
- 212 posts
If it was renderman I would say to change the Output Driver parameter for MotionFactor from 0 to 1. For mantra…. i'm not sure what the option would be called. Mind you I haven't looked at the images but from the description it sounds like the micropolygons are being sampled at a lower shading quality for the depth of field rendering. That would be the case in Renderman so I'd assume it would be similar in Mantra.
I believe Wolfwood posted a nice file for depth of field with mantra on the Odforce pages.
good luck
-k
good luck
-k
- puma.snyder
- 121 posts
- thekenny
- 212 posts
- puma.snyder
- 121 posts
Do you mean to apply DOF and then scale the image down, or first to scale it down and then apply the DOF to it?
I already render the z-depth map at floating point, so no room for improvement there. I tried rendering with mantra DOF, but the render doesn't even start after 10 minutes, so I guess the larger rendering/scaling down option is the only thing I can do.
- deecue
- 412 posts
i don't know how much i can help, but i recently did a project involving a dandelion seed pod with all those tiny seeds coming out of it and each were being animated by sound…
so in order to get the noise down for those suckers, i had an 8x8 supersample and a micro-poly shading level of 3 (at the rop level, rather than obj)..
sounds like crazy render times, huh? well it was.. 2.5 hours/frame when copying the seedlings (lystem actually) to each point of the head pod via copy sop..got that down to 2.5 min/frame after using point instancing instead of copy sop…and practically no noise as well…
hth somewhat… good luck… like your results so far.. keep us updated…
dave
dave
Dave Quirus
- puma.snyder
- 121 posts
