So I have been trying to figure out how to offset instanced animation other then using the standard delayed load procedural method and while I feel there should be a better way, up to this point I have been drawing a blank. Is there a way to reference the points an object is being instanced to outside of the instance geo node kind of like the stamp() command?
I have attached a simple file set up in order to show my dilemma. Basically I would like to use the offset attribute from the instance points inside of the chop net of the box so that each box is offset by a frame depending on the point it is being instanced to. Any pointers or ideas of how this might be achieved with instancing would be awesome!
Offsetting Procedural Animation of Instances
1629 0 1- NFX
- 183 posts
