Im attempting to create a look-at node with a bit more control than the built in look-at constraint has. I have most of it figured out except for the actual look-at constraint part.
here's the code that's causing problems
if self_dist1 < max_dist:
lookatnode = lookat_obj
up_vec = hou.Vector3((0,1,0))
rotmat = self_node.buildLookatRotation(lookatnode, up_vec)
self_node.setCookTransform(rotmat)
and the python node I have it running in is spitting out the following error
Error: Python error: Traceback (most recent call last):
File “<stdin>”, line 41, in <module>
File “/op/hfs.current/houdini/python2.6libs/hou.py”, line 6917, in setCookTransform
return _hou.objNode_setCookTransform(*args)
OperationFailed: The attempted operation failed.
Python object is not cooking
any help would be much appreciated.
writing a custom lookat constraint in a python node
4271 4 0-
- Jeff Raines
- 2 posts
- rafaels
- 702 posts
Sorry if you've already checked this, but the only hint I have is from the doc page on the hou.ObjNode:
This method raises hou.OperationFailed if you call it on an object that is not implemented in Python or if you call it from outside that object’s Python cook code.
Does it help at all?
Cheers
Cheers
Toronto - ON
- Jeff Raines
- 2 posts
- edward
- 8171 posts
- edward
- 8171 posts
