Hi!
Is there a way to delete piecec of geometry permanently? If you look the attached file, it will eplain this more clearly
There is fractured/animated box. In a group SOP, i select pieces that are inside the bounding box, and delete them. The problem is that when the geo comes outside the bounding box, the once deleted pieces reappear.
Delete geometry
2977 6 2- KiLa
- 109 posts
- tony_a
- 86 posts
- hanton
- 36 posts
Hi KiLa, I think the problem is you delete pieces which are inside the bounding box, so when your geometry goes through the bounding box, the deleted pieces will appear again, because they are not inside the bounding box anymore.
“scaling your bounding with the movement of your geometry”, could it solve your problem?
- KiLa
- 109 posts
@badhairday: ty for the reply, but the scene seems to behave just like the one i posted, tho i will get an error when loading it - skipping unrecognized parameter “mergeop” in obj/box/solver1/d/s/toSim
@hanton: yep, that was the way i solved it, but i was wondering if there is a “better” way to do it
- tony_a
- 86 posts
- KiLa
- 109 posts
- neil_math_comp
- 1743 posts
KiLaIt may be worth updating, if you're up to it. There have been a lot of bugs fixed since the initial release of 12.5.
Im using version 12.5.316.22…
