lightgen hdri....dimming lights???
   4513   3   1
Can anyone tell me how to dim the lights after you've imported through the textport - 20 lights from lightgen. My object is completely burned out. I know there is a way of dimming them all at once but I can't figure it out. I dimmed them one by one and it is still rendering one solid burned out color. I have a sphere with a vex decal set to blue and it renders out solid bright blue.
I might need a detailed explanation because i've looked all over the interface and searched in the textport for some kind of command.
the hdri/lightgen for dummies should do.
Thanks so much!
Hey Foxter,
If I remember correctly, there is a variable that controls the “Dimmer” value. Type Alt+Shift+A or go to Settings -> Aliases and Variables, look under the Variables tab for “dimmer” or something like that. You want to set the value down to 0.01 and go from there.
Cheers!
steven
yup, steven's right.. there should also be a couple other variables as well:
lightgen_blur
lightgen_scale
Dave Quirus
thanks steven!
