Hi all,
I'm hoping someone might be able to provide some suggestions on how to get HqueueServer running on Windows 7.
The problem I'm having is I can't even get the HqueueServer service to run. Each time I try to start it it runs for a few seconds then dies. This is what gets written to the error log (trimmed down a bit):
File “C:\HQueueServer\python26\Scripts\paster-script.py”, line 8, in <module>
load_entry_point('PasteScript==1.7.3', ‘console_scripts’, ‘paster’)()
File “C:\HQueueServer\python26\lib\site-packages\pastescript-1.7.3-py2.6.egg\paste\script\command.py”, line 84, in run
invoke(command, command_name, options, args)
File “C:\HQueueServer\python26\lib\site-packages\pastescript-1.7.3-py2.6.egg\paste\script\command.py”, line 123, in invoke
exit_code = runner.run(args)
… ending with…
File “C:\HQueueServer\python26\lib\site-packages\pastedeploy-1.3.2-py2.6.egg\paste\deploy\loadwsgi.py”, line 587, in find_egg_entry_point
possible.append((entry.load(), protocol, entry.name))
File “C:\HQueueServer\python26\lib\site-packages\setuptools-0.6c9-py2.6.egg\pkg_resources.py”, line 1913, in load
entry = __import__(self.module_name, globals(),globals(), )
ImportError: DLL load failed: The specified module could not be found.
Unfortunately I don't know enough Python to make sense of this. I checked that the directories and files exist and they do.
Other stuff I checked:
-Houdini 12.5.376 is installed on the machine that HqueueServer is installed on, licensed (education) and running fine.
-I've tried installing HqueueServer from the installer and installing Houdini and HqueueServer simultaneously.
-Python 2.6 is installed at C:\Python26, environment variables are in place and typing “python -v” at the Windows command prompt tells me Python is working. (Please note I installed Python 2.6 after I couldn't get HqueueServer to start the first time.)
-HqueueServer is installed at C:\HQueueServer. The folder is shared and accessible on the network.
-The machine in question has been restarted multiple times.
Any help would be greatly appreciated! Thanks!
Phil
HqueueServer won't start in Windows 7
1862 1 1- NYU_Animation
- 21 posts
- NYU_Animation
- 21 posts
