I am writing a shared library (procedural) which links external libraries.
When I try to use it within the Houdini environment, I get the following error
dyld: Symbol not found: __cg_jpeg_resync_to_restart
Referenced from: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
Expected in: /Library/Frameworks/Houdini.framework/Versions/12.5.427/Resources/../Libraries/libJPEG.dylib
in /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
Trace/BPT trap: 5
I understand from googling/stackoverflow searches that if one can recompile the code with a consistent version of JPEG, the problem can be resolved.
Unfortunately, I don't have the sources to those libraries so that option is not available to me.
Has anyone else encounter this problem on OS X ? What is the work around ?
Cheers
[HDK] JPEG on OS X : __cg_jpeg_resync_to_restart
2409 0 0- nicholas_yue
- 301 posts
