I am trying to run a pyqt application inside houdini. I get everything to work with the pyqt_houdini helper module, but everything responds really slow and jerky, as if qt does not get polled enough to update.
When I use the thread helper, performance is much better (almost the same as standalone or running on maya and nuke), but I have trouble with other modules, probably because it runs in a separate thread.
I was wondering if there is a way to make the pyqt_houdini solution perform better.
Koen
pyqt_houdini vs. pyqt_thread_helper
1990 0 1- koen
- 789 posts
