Problems with copyDataDOP
   1337   0   1
I'm trying to get a setup in DOPs where I can put in my default method of working with fields and duplicate that for the amount of times I want to do it.
The idea is to control it from the interface with +- to add/remove anything I want.
So I'll have one of the DOP inputs dedicated to sources for instance but be able to split them out in dops by copying the bit of the network I want and cycling through density_0, density_1, density_2 etc…
I could just create say 5-10 branches and switch between them with merges etc, but I'm looking for a more elegant solution.
I've attached an example scene where I'm trying to copy density into each copy and multiply by the copy number. I thought I had it when I switch the sharing data, but the density doesn't update in the I/Os…
HELP!
Christian
P.s. This post is over at OdForce as well, but no-one is biting:
http://tinyurl.com/q5sjxll [tinyurl.com]
copyData_example.hip (732.1 KB)
