hello
i have a D.A uber shader i did which took me a lot of time, and unfortunately it is broken in H13. is there any fix to that?
or i can just restart from scratch?
Shader and DA problem shifting to h13
3368 4 0- sami.tawil
- 172 posts
- halfdan
- 599 posts
sami.tawilFix to what? Can you post the shader and/or the actual errors/warnings you get from H13?
Halfdan Ingvarsson
Senior Developer
Side Effects Software Inc
Senior Developer
- sami.tawil
- 172 posts
it seems the problem comes from the surfacemodel node in the shader
it seems also that new connection are created, and pluged in the wrong input in the surface model
mantra: Unknown parameter: ‘falloff’
mantra: Unknown parameter: ‘diffuseRamp_the_basis_strings’
mantra: Unknown parameter: ‘(’
mantra: Unknown parameter: ‘catmull-rom’
mantra: Unknown parameter: ‘)’
mantra: Unknown parameter: ‘diffuseRamp_the_key_positions’
mantra: Unknown parameter: ‘1’
mantra: Unknown parameter: ‘diffuseRamp_the_key_values’
mantra: Unknown parameter: ‘BaseColorRamp_the_basis_strings’
mantra: Unknown parameter: ‘linear’
mantra: Unknown parameter: ‘BaseColorRamp_the_key_positions’
mantra: Unknown parameter: ‘0.970588207245’
mantra: Unknown parameter: ‘BaseColorRamp_the_key_values’
mantra: Unknown parameter: ‘0.699999988079’
mantra: Unknown parameter: ‘colorMapIntensity_the_basis_strings’
mantra: Unknown parameter: ‘colorMapIntensity_the_key_positions’
mantra: Unknown parameter: ‘colorMapIntensity_the_key_values’
mantra: Unknown parameter: ‘specularIntensity1_the_basis_strings’
mantra: Unknown parameter: ‘specularIntensity1_the_key_positions’
mantra: Unknown parameter: ‘specularIntensity1_the_key_values’
mantra: Unknown parameter: ‘specularColorRamp1_the_basis_strings’
mantra: Unknown parameter: ‘specularColorRamp1_the_key_positions’
mantra: Unknown parameter: ‘0’
mantra: Unknown parameter: ‘specularColorRamp1_the_key_values’
mantra: Unknown parameter: ‘specMapIntensity1_the_basis_strings’
mantra: Unknown parameter: ‘specMapIntensity1_the_key_positions’
mantra: Unknown parameter: ‘specMapIntensity1_the_key_values’
mantra: Unknown parameter: ‘specularIntensity2_the_basis_strings’
mantra: Unknown parameter: ‘specularIntensity2_the_key_positions’
mantra: Unknown parameter: ‘specularIntensity2_the_key_values’
mantra: Unknown parameter: ‘specularColorRamp2_the_basis_strings’
mantra: Unknown parameter: ‘specularColorRamp2_the_key_positions’
mantra: Unknown parameter: ‘specularColorRamp2_the_key_values’
mantra: Unknown parameter: ‘specMapIntensity2_the_basis_strings’
mantra: Unknown parameter: ‘specMapIntensity2_the_key_positions’
mantra: Unknown parameter: ‘specMapIntensity2_the_key_values’
mantra: Unknown parameter: ‘refractionIntensity_the_basis_strings’
mantra: Unknown parameter: ‘refractionIntensity_the_key_positions’
mantra: Unknown parameter: ‘refractionIntensity_the_key_values’
mantra: Unknown parameter: ‘refractioncolor_the_basis_strings’
mantra: Unknown parameter: ‘refractioncolor_the_key_positions’
mantra: Unknown parameter: ‘refractioncolor_the_key_values’
mantra: Unknown parameter: ‘refractionMapIntensity_the_basis_strings’
mantra: Unknown parameter: ‘refractionMapIntensity_the_key_positions’
mantra: Unknown parameter: ‘refractionMapIntensity_the_key_values’
mantra: Unknown parameter: ‘emissionIntensity_the_basis_strings’
mantra: Unknown parameter: ‘emissionIntensity_the_key_positions’
mantra: Unknown parameter: ‘emissionIntensity_the_key_values’
mantra: Unknown parameter: ‘0.5’
mantra: Unknown parameter: ‘emissionColor_the_basis_strings’
mantra: Unknown parameter: ‘emissionColor_the_key_positions’
mantra: Unknown parameter: ‘emissionColor_the_key_values’
mantra: Unknown parameter: ‘0.442000031471’
mantra: Unknown parameter: ‘0.702400028706’
mantra: Unknown parameter: ‘emiddionMapIntensity_the_basis_strings’
mantra: Unknown parameter: ‘emiddionMapIntensity_the_key_positions’
mantra: Unknown parameter: ‘emiddionMapIntensity_the_key_values’
- halfdan
- 599 posts
sami.tawilThis is odd. Looks like all the connections got shifted ever so slightly. There is supposed to be code to prevent this from happening, but that didn't seem to work here. We'll investigate that. In the meanwhile, I've attached the fixed version of your OTL.
Halfdan Ingvarsson
Senior Developer
Senior Developer
- sami.tawil
- 172 posts
