I have the following code in a python otl which gives me error message unless I suppress the if statements part of code. (hip file and olt are attached)
Advices are appreciated!
import math
# This code is called when instances of this SOP cook.
node = hou.pwd()
geo = node.geometry()
# Add code to modify the contents of geo.
point = geo.points()
position = point.position()
origin = hou.Vector3(0,0,0)
north = hou.Vector3(0,1,0)
vertical_surface_normal = hou.Vector3(0,1,0)
distance = hou.Vector3.distanceTo(position, origin)
zeta = 90 - hou.hmath.fit(distance, 0,1, 0,90)
pai = hou.Vector3.angleTo(position, north)
surface_normal_azimuth = hou.Vector3.angleTo(vertical_surface_normal, north)
diff_btw_pai_and_surface = pai - surface_normal_azimuth
height = math.cos(math.radians(zeta))*math.cos(math.radians(diff_btw_pai_and_surface))
if height < 0:
height = 0
attrib_h = geo.addAttrib(hou.attribType.Point, “H”, 0.0)
point.setAttribValue(attrib_h, height)
point.setAttribValue() error
4056 2 1- oat
- 479 posts
- graham
- 1908 posts
What is the error message exactly? (Sorry, don't have time to check the file).
Edit:
The only glaring thing I see is your handling of a negative height. If the height is less than 0 you are setting it to the integer value 0, which might cause a problem with the setAttribValue() call. Try setting height to 0.0 in that case, since it expects a float.
Edit:
- oat
- 479 posts
