I am trying to follow Peter Quint's DOP Forces video tutorial and in the section where he uses the Uniform Forces shelf tool, then is prompted to select dynamic objects for Uniform Force. He then uses box selection to select a number of dynamic objects before hitting enter. The force node is then created and the Group parameter is automatically populated with the group names of the objects he selected.
This should all be very simple, but in H13 I am unable to do this. I am prompted to select dynamic objects but no matter what I try I cannot seem to select just a few of the objects. If I box select every object, when I hit enter the uniform forces node is only using the first objects group from each rbd point object (Boxes on one, spheres on the other). I know each object has its own point group as they show up in details view for my DOP Network (there is sphere_0…sphere_49 and the same for boxes). Of course the force dop node works fine if I type the group names in manually, but this is a pain and defeats the purpose of using the shelf tool entirely.
Any suggestions?
Unable to box select dynamic objects for shelf tools
3219 7 0- Josh Oram
- 43 posts
- Josh Oram
- 43 posts
- anon_user_37409885
- 4189 posts
- Josh Oram
- 43 posts
Here is the file. In the video, he used the Uniform Force shelf tool, then selected a number of boxes and spheres in one corner of the grid, hits Enter and the node is created with only those objects affected by the force. I am only able to drag select either all the boxes, or sometimes it will select one object of each type, box_0 and sphere_0. I am following exactly what he does in the video. Every box and sphere have their own group that should be selectable. You can confirm this by looking at the details view of the DOP network.
Running 13.0.334 on Win7 x64 GTX780 gpu with latest drivers
- 4189 posts
- Josh Oram
- 43 posts
- MCGrund
- 18 posts
- 4189 posts
