Hi!
I'm making a fountain and so far I have already rendered my water quite a few times, but I tried to render today and it wont show up. All I changed was the particle separation in attempt to make the fluid more realistic ( current value 0.02)
and another question
I am trying to create some sink objects and after I select the objects that I want to be sinks, Houdini won't let me select the fluid to interact with it. Is there a certain setting I need to be on?
Thanks,
Houdini Student
Water not rendering (flip fluid)
2457 2 2- mbuzia20
- 1 posts
- AlphaJoe
- 11 posts
- Sadjad Rabiee
- 1391 posts
AlphaJoe
I am having this exact same problem. Did you find what was wrong? I had created a flip tank and added a source volume to disturb the points and create some waves. When I render, the surface doesn't show up, but it is visible in the 3D view.
Maybe that's because Render flag ,Can you upload a simple example about your problem :? :?:
