Keep only looping edges
   3900   8   0
Hi everyone,
I'm stuck on something that looks so simple… I have this mesh, which is made with a lot of looping edges, and my goal is to only keep these edges (I don't want the one that goes on the Y axis, but don't refer to that axis because I have some mesh that are not oriented this way).
Do you have a simple solution ?
Thanks,
Tom.
ExtractLoopEdges.rar (14.7 KB)
https://vimeo.com/obreadytom [vimeo.com]
Hi Tom,
(Edge) Dissolve SOP will do the trick…
Example attached.
Tricky part is getting the edges to dissolve, but edge group options can take care of a lot of cases (and Carve to extract the cross sections sans primitives)
edge_dissolve.hip (63.6 KB)
Nice ! Thanks Adam.
One more question, it's seems that the points are not connected anymore… For example with a Connectivity SOP they are all independent from each other. How can I correct it ? I need each circle to be one geometry.
Happy to help.
Fuse SOP will consolidate the points.
Use two ConvertSOPs.
First one:
Convert To - set to NURBS Surface
Connectivity - set to Rows
V Order - set to 2
Second one:
Convert To - set to Polygons
Yeah the convert approach is nicer. *screwy face*
Ah, got it !
Unfortunately, this was nos working for both of your solutions on my geometry (maybe it works on Adam's one). I converted it into a NURBS Curve, and then fused it (the fuse was not working at all until my geo was converted).
Thanks !
EDIT : working only with the fuse now, strange
I tested this on your geometry. Didn't even looked at AdamT file.
My file is actually a entire tree, and each branch is in a ForEach SOP, maybe it's coming from here (I gave you only one branch).
