Bit of a daft one and I have a work around for this, just checking if I missed anything.
I have a smoke sim setup with rotated domains using positionDOP. I then have some gasFieldVops that are pointing to CVEX operators to do extra things to the sim.
It would be handy to be able to access the position data (mainly orient) to be able to correctly calculate forces correctly if the domain is rotated etc. My work around is for the user to point at the domain object, but I'd like to do this automatically if possible.
So. I need to pull in the positionData into a gasFieldVop without doing expressions that point to nodes, has to just pull in the data.
Thanks for any help
Christian
Accessing DOP Position in gasFieldVop externally in SHOPNET
1534 0 1- niietzshe
- 42 posts
