Cookie Problems
   3777   6   1
hi
i found problem in houdini when i use cookie node!
see my project file
as you can see teapot fracture by curve but same area on top of teapot disappear!
is it bug in houdini?
sometimes you can solve this problem use poly spline to get more point on curve but have we another way to fix that?(in this example poly spline doesn't work)
in complex geometry this problem make more mistake for us!
thanks for your helps.
Cookie Problem.hip (87.8 KB)
with a fuse i could solve the problem.
cookie_problem_343_fuse.hipnc (85.3 KB)
very thanks it's work best.
next example is more complex with add fuse still we have problem:
in this case how can we do?
thnaks for your help
Problem.rar (670.2 KB)
for this i don't know if it's the best way but i just resample the cutting mesh. like that the cookie sop will get more mesh data in input b.
Fracture Problem_resample.hipnc (62.0 KB)
you want some cookies that will blow your mind???
the guys from groboto did an amazing job doing booleans
http://www.groboto.com/v3/Documentation/ToolsMethods/Modeling%20Basics [groboto.com]
later on implemented in Modo.
https://www.thefoundry.co.uk/products/modo/plugins/meshfusion/ [thefoundry.co.uk]
thanks it's great.
