Converting a curve from 1 prim to lots of prims
   10325   10   3
Think I'm being stupid here…
I want to convert a polygon curve ( 1 poly, 1 prim, 200 points )
to…
another polygon cuvre ( 200 polys, 200 prims, 200 points ).
(bit confused here.. I thought in polys edges and surfaces had to be primitives)
Cheers
H
Henster
I think this is quite tricky. I can only think of two ways to do it. Neither of which are very straight forward. If I understand you correctly you want point 0-1 to become poly 0, points 1-2 to become poly 1, points 2-3 to become poly 2, and so on……
In which case you would only end up with 199 polys. The easiest way I can think of to do this is to make a copy of your curve, delete the first point and add a new point on the end. Then skin the two curves together in columns.
Not in front of Houdini but I think that should do the trick.
My solution took: 1 delete sop, 2 add sops, 1 merge sop
Try Carve SOP:
First U: 0
Second U: 1
Breakpoints mode
Cut at all internal U breakpoints : On
edward
explain…. :?
AndrewVK
Try Carve SOP:
First U: 0
Second U: 1
Breakpoints mode
Cool… nice one
I'm not getting 100% accuracy off the carve sop method… Not quite enough primitives. Two chunks of line are being treated as one..
nice idea though
H
Henster
Heya Henster,
Give the following a try.
Append a delete SOP to your curve. Set delete method to “Delete Non-Selected”
put `param(“copynum”,0)`-`param(“copynum”,0)+1` in the pattern field.
Append a copy sop to the delete sop.
flip over to the stamping page, and type “copynum” in the var1 field, and $CY in the param1 field.
Enable stamping. Set number of copies to 200.
Does that work?
Gene
Hoorah! it works!
very nice. thanks gene.
Just a side note to anyone who tries this… ( I'm sure they'll be queueing up) remember to set the delete sop to points not prims.
Cheers
H
Henster
How can one reverse this process ? I have medical model of liver veins that consists of zilion of two-point curves. Problem is that most of them are branched, therefore ConvertSOP doesnt want to work. Any sugestions ?
For far does Fuse get you?
