set packed pieces Active
   2305   2   1
in a bullet sim, I have a simple fractured torus (packed primitives) and I'm hitting them with a sphere,
I've used another thread to figure out how to activate the torus on the impact of the sphere but I can't figure out how to activate just the pieces that are hit - instead of all the pieces at the same time…
I'm sure the pop wrangle is involved but I'm stuck on how to control the ‘active’ attribute using the ‘impulse’ data.
Training Lead
www.sidefx.com
If you're looking at the impact data, the ‘primnum’ / ‘otherobjprimnum’ fields should tell you which packed primitives were hit, and you can then set the ‘active’ point attribute on those primitives.
I was hoping to do it by filling a group with pieces that have an impulse above some value - then let the regular forces have an effect…
Training Lead
www.sidefx.com
