Setting Bone Rest Angles Doesn't Work
   3036   2   0
I'm following this procedure to set the bones rest angles (http://www.sidefx.com/docs/houdini13.0/character/restangles) [sidefx.com] but when I rotate the bones, although I see the angle change in the Bone tab > Rest Angles parameters, the bones stay still in the viewport.
I have changed the Edit > Objects > Bone Kinematic Override: IK Rest, but it doesn't make a difference.
What am I missing?
Thank you!
H 13.509
UPDATE:
Attachment 1) If I rotate the bone to the right, the bone is still in its initial position although you can see the guide has moved
Attachment 2) If I pull on the (elongate) red arrow on the bone, suddenly the bone jumps to the guide in the display
Winter is coming!
Sounds like an update bug to me. Please log a bug report using the Support menu above.
edward
Done - thank you!
Note: Viewport displays properly upon closing and opening file, but this is a frustrating way to work.
bone_problems.hipnc (50.3 KB)
Winter is coming!
