viewer Path tool
   2245   2   1
Simple question,
I'm trying to create a path with pathCVs. In the documentation it is written:
The Path object is a regular Geometry object with default geometry operators that define an oriented curve (path). This object should be created using the viewer Path tool. If it is created in Network View, then one needs to manually setup the paths inside this object’s points_merge geometry node.
http://www.sidefx.com/docs/houdini13.0/nodes/obj/path [sidefx.com]
My question is: where is the “viewer Path tool”?
I think I've seen it before, but I can't find it anymore…
Press Tab in Scene View Pane (3d viewport) and write Path, hit enter. It will run the Path Tool.
Awesome, thank you
