I created a custom SOP. Sometimes I can cook it successfully, other times it segfaults. It seems to always segfault after the “cookMySop()” function completes (i.e., outside of the code that I wrote???). When it segfaults, it either gives me one of two error logs, or no error log at all.
Here are the two error logs. Can anyone make sense of them and direct me in a direction that I can start to look to debug this?
Log version 1:
Caught signal 11
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler:perator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
<libpthread.so.0>
UT_StringArray::entries() const <libHoudiniUT.so>
GT_AttributeMap::GT_AttributeMap(GT_AttributeMap const&) <libHoudiniGEO.so>
GT_AttributeList::addAttribute(char const*, UT_IntrusivePtr<GT_DataArray> const&, bool) const <libHoudiniGEO.so>
GT_PrimVolume::getPointPrimitive() <libHoudiniGEO.so>
GR_PrimVolume::update(RE_Render*, UT_IntrusivePtr<GT_Primitive> const&, GR_UpdateParms const&) <libHoudiniAPPS3.so>
GUI_GeoRender::updatePrimitives(RE_Render*, GR_DisplayOption*, UT_Array<UT_IntrusivePtr<GT_Primitive> >&, GT_RefineParms&, GR_UpdateReason, GR_DecorationOverride, char const*) <libHoudiniAPPS3.so>
GUI_GeoRender::update(RE_Render*, GR_DisplayOption*, GUI_SetupResult, GR_DecorationOverride, char const*, bool&) <libHoudiniAPPS3.so>
GUI_DetailLook::updateForRender(RE_Render*, GUI_DisplayOption&, RE_LightList*, GR_DecorationOverride, char const*, bool&) <libHoudiniAPPS3.so>
DM_VPortAgent3D::setupGeometry(RE_Render*) <libHoudiniAPPS3.so>
DM_VPortAgent3D::renderViewport(RE_Render*, int, int, bool, bool) <libHoudiniAPPS3.so>
DM_VPortAgent3D::doRender(RE_Render*, int, int) <libHoudiniAPPS3.so>
DM_Viewport::doRender(RE_Render*, int, int) <libHoudiniAPPS3.so>
UI_Feel::renderMe(RE_Render*, int, int) <libHoudiniUI.so>
UI_Feel::doRenderKids(RE_Render*, int, int) <libHoudiniUI.so>
UI_Feel::doRender(RE_Render*, int, int) <libHoudiniUI.so>
UI_Viewport::reRender(RE_Render*, bool) <libHoudiniUI.so>
UI_Window::renderChildViews(RE_Render*) <libHoudiniUI.so>
UI_Window::doRedraw() <libHoudiniUI.so>
UI_Queue::doWindowRedraws() <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main_part2(int, char const* const*) <libHoudiniUI.so>
main <libHoudiniUI.so>
<libc.so.6>
_start <houdini-bin>
Log version 2:
Caught signal 11
<libpthread.so.0>
RE_TextureFont::getGlyphInfo(unsigned int) <libHoudiniUI.so>
RE_TextureFont::getStringWidth(unsigned char const*, unsigned char const*, UT_Unicode::transform const*) <libHoudiniUI.so>
SI_DopeSheet::renderFrameIndex(RE_Render*, float, float, int, int, int, int, double) <libHoudiniUI.so>
SI_DopeSheet::renderFrameIndicator(RE_Render*, int, int, float, float) <libHoudiniUI.so>
SI_DopeSheet::doRender(RE_Render*, int, int) <libHoudiniUI.so>
UI_Window::doRender(RE_Render*, int, int) <libHoudiniUI.so>
<libc.so.6>
Any idea what these error logs mean?
1692 3 0- Kalina Borkiewicz2
- 5 posts
- Anonymous
- 678 posts
- 5 posts
- Anonymous
- 678 posts
Mialem przypadek gdy caly kod z metody Cook() dzialal dobrze ale podczas ladowania Houdego wyskakiwal mi blad o nieodpowiednim tagu w “$HOME\houdini13.0\config\Dialogs\”. Chyba tam jakas informacja o UI jest tworzona.
Nie pomagala ponowna recompilacja ani wykasowanie katalogu $HOME aby Houdy przetworzyl dane jeszcze raz. Zrobilem nowe pliki i dokladnie ten sam kod linijka po linijce napisalem i poszlo . Do tej pory nie wiem co bylo powodem.
