Glue Object not collapsing under it's own weight
   3339   4   0
At this stage (screenshot) why is it not collapsing under its own weight?
If I either add more weight or reduce the glue value it will start collapsing under its own weight from frame one, and just a liiiittle bit more and it's the most stable structure in the world…
I feel that I am missing something..
EDIT: Attached .hipnc file
Board_House_Locked.hipnc (605.0 KB)
/M
Personal Houdini test videos, http://vimeo.com/magnusl3d/ [vimeo.com]
Only way I have managed to get around it sofar is to find a seed value of the “bullets” to not make such big overhanging chunck, like in this test video I put on vimeo.
https://vimeo.com/112326057 [vimeo.com]
But I would be so much nicer if overhangs could collapse under their own weight.
/M
I guess you would need to use Hard Constraint for effects like that
Thanks Tamte, where would I start to look into those ?
/M
Even with this little help I have studied and tried out several things, so I just wanted to say your feedback was awesome Tamte ! this is my “progress”.
https://vimeo.com/112567127 [vimeo.com]
https://vimeo.com/112649381 [vimeo.com]
https://vimeo.com/113254657 [vimeo.com]
/M
