I create 4 scalar fields with values from 0 to 1.
Merge them together, name them Cd.x, Cd.y, Cd.z and density.
Why dont they show as colored volume ?
Why does the trail sop not find the Cd fields ?
Error message on trail node:
Cannot find any volumes of name Cd
Problem with color field
4081 8 2- dulo
- 383 posts
- PradeepBarua
- 443 posts
- PradeepBarua
- 443 posts
- PradeepBarua
- 443 posts
- dulo
- 383 posts
- dulo
- 383 posts
PradeepBaruaWhy dont they show as colored volume ?
Only density is get displayed on viewport. So use “volumevisualization” sop and type “Cd.x” or “Cd.y” or “Cd.z” or “Cd.*” in Density Field.
Yes, but the fourth node in the merge is a rename to density.
Shouldnt that be enough for the volume to show up in the viewport ?
- PradeepBarua
- 443 posts
- PradeepBarua
- 443 posts
And one more thing, you are using Iso Offset to calculate SDF Volume (which is scalar) and naming it vel and without changing anything inside volumevop you're renaming those as Cd.x, Cd.y and Cd.z. That means all are the same. they hold exact same values.
Merge will return a vector volume with all the same three components.
Edited by - Nov. 25, 2014 04:57:42
- dulo
- 383 posts
