Problem in Points Colour Gradient
   3877   2   0
Hey !
Im new to houdini and I'm learning by some tutorials
in a part of it i need to give thickness to the spoon and i should do it with points node - color gradient ( … –> point –> VOP SOP –> attribpromote –> Polyextrude –> … )
But the gradient is not in the right direction
as you can see its on X axis - left to right
http://www.imagesup.net/?di=014183398989 [imagesup.net]
http://www.imagesup.net/?di=714183400305 [imagesup.net]
but it needs to be like this on the Z axis - up to down
http://www.imagesup.net/?di=814183401143 [imagesup.net]
and sorry if its so simple but i couldn't find out how to do it !
the gradient is along x axis since you are using $BBX which at your first 2 images is across the spoon
so just change your expression to $BBZ or 1-$BBZ to get gradient in Z axis
in your 3rd image X is actually along the spoon so in there $BBX would work
tamte
oh thanks so much !
it really helped me out !
