Persist attribute values
   3082   3   1
I am new to Houdini and not grasping how attributes work.
First I created “Add” node to create a point.
Then I have created attributes in “Attribute Create” node called @posx and @frameno (@frameno value is $FF).
I then created a “Point Wrangle” node with the following vex code:
if(@frameno < 100){
@posx = @frameno;
The @posx attribute indeed increments, but once @frameno gets past 100, the value returns to zero. What is the method to have these attributes retain their values?
Thank you,
Caesar
@posx is not defined outside the if statement, that mean it's initialized to default value that is usually zero (or random value in some programming language).
use:
float max = 100;
@posx = max-1;
if(@Frame < max){
@posx = @Frame;
Maybe a solution, too :-?
Please have a look here, too:
http://vimeo.com/6803463 [vimeo.com]
http://vimeo.com/6803615 [vimeo.com]
http://vimeo.com/6803939 [vimeo.com]
and then
http://vimeo.com/15923855 [vimeo.com]
if_in_expression.hip (31.5 KB)
if_in_expression-detail-attribute.hip (58.5 KB)
Thank you gentlemen - I will give it a try when I get home.
~Caesar
