Houdini projects folders?
   6363   7   1
Hi, I noticed Houdini doesn't create “projects” like XSi or Maya, with subfolders such as “pictures”, “scènes”, “render_pictures”, etc.
How do you deal with that? Do you create subfolder with the same structure as a Softimage project?
Thanks and happy new year!!!
David
Houdini gamboler
There is a structure but it has do be done manually. In H14 you will get a project manager if you can wait the 15.01.15 will be your date. :-)
Excellent !
I just read this. This is sooo good.
you can see it on the sneak peek H14 Video :
https://www.sidefx.com/index.php?option=com_content&task=view&id=3029&Itemid=66 [sidefx.com]
Hey just one more question : in which folder in the project should I put *.hip files? In the HDA folder?
Houdini gamboler
The structure itself suggests you drop them at project level so you will use $JOB/geo and $JOB/renders but $JOB/filename.hip
I don't particularly like it but I see why they have gone in this direction, it is simple and $JOB and $HIP are unified so kind of makes sense.
I do create my own hip folder though.
Thanks a lot Jordi!
And thanks for your answer on the shared properties, I was waiting to experiment a bit on your solutions before replying…
Have a nice end of weekend! 8)
Houdini gamboler
