I imported a bgeo geometry and use a python node to write out each polygon's centroid position and normal. However, I got the error message that “Surface” object has no attribute “normal”.
What I don't understand is that I can see the normal lines when I turn on surface normal display. And the same python node works fine with other polygons created in Houdini.
May I ask how to get the normal back?
