hello,
What is upper frame ruler meaning? It's different from lower ruler. I can't find in document.
thanks!
2161 2 1- jerry7
- 620 posts
- halfdan
- 599 posts
jerry7It's the current time and the timeline representing it. The smaller numbers should delimit a chunk of frame and the number before the current marker and the number after, should be less than and greater than the current frame.
hello,
thanks!
However, yours looks very weird. Can you post the scene?
Halfdan Ingvarsson
Senior Developer
Side Effects Software Inc
Senior Developer
- jerry7
- 620 posts
halfdanjerry7It's the current time and the timeline representing it. The smaller numbers should delimit a chunk of frame and the number before the current marker and the number after, should be less than and greater than the current frame.
hello,
thanks!
Nothing in scene. I'v tried many times.
Start new scene , in animation panel use mouse wheel zoom out to a large frame range and use MMB pan left/right several times . then upper and lower ruler will lost sync.
