I want to connect the small polygons to the pieces they belong but I have no idea how to do it. Can someone help me with that? Please see the picture and also the file attached.
Thank you
Separated pieces
1548 2 1- feresteanud
- 27 posts
- Andy_23
- 918 posts
Hi there,
in your file you create a point group from a bounding sphere to select your voronoi pieces. But your group does not contain all points of the pieces, so when you delete all points outside of your group you end up with ‘open’ pieces.
A way to ensure you end up with all points of the pieces that fall inside the bounding sphere is to expand the original point group with a second group node as shown in the attached file (edge tab).
It's not a direct answer to your question, but I think a solution to what I imagine you're trying to achieve.
I hope it helps you,
Andy
Andy
- feresteanud
- 27 posts
