I'm wondering why my attached setup doesn't work? The switch should change the input (and therefore pitch) of the tone at frame 50.
I presume the audio is all calculated for playback in the first frame therefore doesn't switch. What would be better approach to this problem?
Audio Switch in Chops
2961 2 0-
- Simon Russell
- 166 posts
- tamte
- 9728 posts
you may be right, that the audio is precached from channel at the start
as Switch CHOP is switching the whole channels it will not update in the middle of playback
you can use Blend CHOP instead to create switching/blending within the channel value itself and therefore it will be considered in precached audio
- Simon Russell
- 166 posts
tamte
Thanks Tomas that's great
