I have installed the recent versions of H13 (13.0.729) and H14 (14.0.291) using local licensing for ease of administration.
I have been using local licensing for about 1 year now.
Whilst the application works (licensing wise), I have not been able to render with Mantra
hkey tells me I have 1 render token for each H13 and H14
when I render in either version, I get
“No licenses could be found to run this application.
Please check for a valid license server host”
Has there been recent changes to how Mantra is retrieving licenses ?
Cheers
Rendering license : checkout problem
2612 3 0- nicholas_yue
- 301 posts
- nicholas_yue
- 301 posts
- nicholas_yue
- 301 posts
Solved!
I had a stale copy of Licensing.opt in the $HOME directory and I was firing up Houdini from my $HOME.
I was reorganising my directories due to disk space and had left a copy of Licensing.opt in $HOME that points to a non-existent license location.
I did have an updated and correct copy of Licensing.opt in $HFS/houdini
I started houdini in $HOME, it works fine I guess because houdini looks for licensing configuration in $HFS/houdini so that works fine.
Whereas for mantra, the search order is different (I discover this through strace), mantra found a Licensing.opt (stale) in the current directory ($HOME) and used that instead of $HFS/houdini
I guess mantra search order needs to take into account farm/network rendering requirement.
I thought I write this up as it might benefit others.
Cheers
Cheers
Nicholas Yue
- dooori
- 1 posts
