bullet active parameter
   2803   1   0
I am trying to activate bullet simulation with “active” parameter after a certain frame using a POP wrangle DOP. It works correctly but if I try to activate the object after 2 seconds it does not work anymore.
I got the same results using sop solver, what am I missing?
rbd_active_problem.hiplc (119.6 KB)
You need to uncheck the enable sleep parameter , bullet tab . On your RBD object node.
Rob
Gone fishing
