Hi!
i can see the “auto-gen reflection map” function can generate a cubic environment map. What about if I have a spherical environment map? How can I tell Houdini to read the “environment map” if it is in spherical or cubical format?
thanks you for your attention!
environment map question
2340 1 1- brucelay
- 313 posts
- thomaskinga
- 65 posts
Hi..
You should be able to use isixpack to create environment/reflection maps from images.
You can simply go into the houdini bin folder using the command prompt/line (cmd for
windows I guess) and enter isixpack for a quick help on the usage of the tool.
The other command line tool to have a look at is iconvert.
Hope that helps..
Tom
Hope that helps..
Tom
