Hi,guys,
I am trying to build a digital asset here,It's a asset inside shader,I mean it's at vex builder level.
And now I want there to be some parameter which link to a rotation of an object level camera.
Because the rotation keep changing,so I must like write a expression for the parameter of the DA.
And here is the problem,it seems that I can't write expression at vex builder level,it does not update.
I know I can promote parameter to shader level,but I do want to keep it at my digital asset which is at vex builder level.
So,how can I get that changing data and make it work for my digital asset?
I did some test,maybe someone can check my test scene(houdini14) and help.
Thank you guys.
Peng.
how to update parameter in vex builder level?
3495 1 1-
- pengzhang
- 12 posts
- Sadjad Rabiee
- 1391 posts
