How do you run scripts
   3004   4   0
I want to run the FromHoudini2Nuke script to export a camera. I'm not finding a whole lot. I did open the Python Shell and attempted to run the following…
execfile('cFromHoudini2Nuke.py')
Nothing happened.
You can also run a script by opening Window/Python Source Editor and pasting the code into the window. When you click Accept the code will run.
Where did 'FromHoudini2Nuke.py come from? Is there a download link or is it a custom script you wrote?
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
http://www.sidefx.com/index.php?option=com_wrapper&Itemid=147 [sidefx.com]
That's the link and the download is on that page. Thanks for the info. I will give that a try and post back.
Well I did that and I didn't get any results that way either. However, in the commented out header I did see a site listed to check for updated versions. I went to her site and found a zip with some detailed instructions. I will try looking into that.
Here's the site if anyone needs.
http://janoberhauser.gute-filme-enden-nie.de [janoberhauser.gute-filme-enden-nie.de]
Can't you use alembic to export the Camera to nuke?
