is there way i can Ctrl + C then Ctrl V copy faces
   2810   3   0
is there way i can Ctrl + C then Ctrl V copy faces (primitives Houdini calls them) from select faces pasted them into group node eg (pattern)
I am having hard time selects and then uses faces i want, because all depends node pull of shelf or your in main window or object windows
or is there way set up and Hot key so will make a group node with selected faces ? ( or mouse right mouse right click menu ) both would be great
Just make your selection and then click on the Group tool under the Model tab along the top of the interface. This will create a group node and populate the pattern field with your selection.
If you really need a copy of the original or new group you can split the network as you see fit.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
I'm sure something like this was possible but I can't find it now…
anyway
RFE #72209
allow copy/paste of selection string….
Training Lead
www.sidefx.com
thank you both but after reading Enivob did bit more searching you gave me the idea see if there hot key for shelf item so searching the forum i found this work perfect
what Doudini said here see URL
but instead of “materials”
i just add “group” made hot key (you do need make a new custom shelf add the item you want to add keyboard short cut )
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=38238&sid=6a7e400b24cf92ac4f665dd19007084d [sidefx.com]
