Hello all,
I am currently trying to apply motion capture data, but have run into a slight problem. I have the .bvh files and I want to run the mcbiovision command so it can convert into the files read by houdini. However, I am using a Windows computer and it does not recognize a command like that on the command prompt, the terminal for windows.
Is there a path I need to set or some other step I need to do to make the command prompt recognize and able to run this command?
Please help, kinda urgent.
Motion Capture conversion
3691 4 1-
- Justin Bloomer
- 13 posts
- goldfarb
- 3466 posts
- Justin Bloomer
- 13 posts
Okay, I found that and got it to work. Now my next question is this. Is there a way to clean up the bclip data, so that the rig starting rotations are the defaults and the rest of the motion data is based on that?
Right now it brings in a rig and all the bones have weird rotations on them, so if I want to apply the motion data to my own rig it won't work. Is there a process to go by that would work?
- Justin Bloomer
- 13 posts
- goldfarb
- 3466 posts
