So I have been reading all over, trying to figure this out and am stumped, I have a simple scene, geometry that I broke up with voroni then did a sim on it, so I'm trying to save out mdd's and the object as an obj, but the point count does match the obj that is saved out.
so I save out an obj, right after the voroni fracture, and that looks right when I bring it back into houdini, but when I apply the mdd, the geometry goes garbage, and other apps say, the point number doesn't match.
and the mdd file is much smaller than I would expect, so I saved out an obj from the dopimport1, “the same place I'm using to save the mdd” and that obj is tiny and just points, but the points aren't the vertices of the geometry it seems they are almost like transform points for each peice.
which makes sense why they don't match up, but how does one convert it from transform parts data to point data, so that the mdd matches the obj that is exported?
Chris
mdd doesn't match geometry
1193 1 1- chris wells
- 57 posts
- chris wells
- 57 posts
