Scatter SOP with a normal from the input surface
   5623   2   1
Hi.
I'm trying to scatter points across my geometry. I'm using the scatter SOP to generate the points and then I'm using a copy SOP to stamp in another piece of geometry onto the points.
Each one of the points that I've spawned has a position, but I wanted to also save a normal direction from the surface where the point was spawned.
I'm trying to have the objects that I stamp align with the surface underneath.
Any help would be appreciated
-Gisli
Put a Facet SOP before Copy and turn on Post Compute Normals on the point cloud.
There's also the new Normals SOP you can use to add vertex/point/primitive normals.
I'm o.d.d.
