Hello
I have this error message when i try to render using Renderman
I have Houdini 15
and i just downloaded renderman from pixer
but i have this message
CreateProcess failed for ‘prman’
any idea how to fix that
Renderman error
11484 10 2-
- Anas Kassis
- 11 posts
- rafal
- 1473 posts
Perhaps ‘prman’ is not in your PATH variable?
See these docs regarding setup for RMANTREE and PATH variables:
http://www.sidefx.com/docs/houdini15.0/render/renderman [sidefx.com]
- Anas Kassis
- 11 posts
Thank you very much
But where i should go in order to adjust that : From where
In order for Houdini to be able to find all the necessary RenderMan tools, first you will need to set a few environment variables:
ensure the RMANTREE is set to the installed version of RenderMan, for example:
export RMANTREE=/opt/pixar/RenderManProServer-20.0
ensure the search path includes the bin subdirectory of RenderMan, for example:
export PATH=$PATH:$RMANTREE/bin
set the HOUDINI_DEFAULT_RIB_RENDERER to the desired version, for example:
export HOUDINI_DEFAULT_RIB_RENDERER=prman20.0
After setting up these three environment variables, Houdini should be able to use RenderMan.
Thank you
Thank you
- gfxfx
- 91 posts
- rafal
- 1473 posts
It depends on which Windows you are running. Here are the step-by-step instructions (or search for “setting environment variables on windows”):
http://www.computerhope.com/issues/ch000549.htm [computerhope.com]
When setting the path variable, append a semicolon to what's already there and then specify the path to renderman's bin subdirectory.
As for the RMANTREE variable, it is probably already set there by RMan's installer.
- gfxfx
- 91 posts
- mosssi
- 51 posts
- gfxfx
- 91 posts
- Anas Kassis
- 11 posts
- ever4nuke
- 7 posts
- bonsak
- 459 posts
Program Files/Pixar/RenderManProServer-20.6”
