In the sidefx docs it says you should use “Direct Reflect” layer using the “Per Light” option in Mantra.
http://www.sidefx.com/docs/houdini15.0/render/noise [sidefx.com]
Okay, so maybe I'm blind, but I've been up and down the options in the Mantra > Images > Extra Image Planes but I cannot find anything that reads exactly as “Direct Reflect”.
Closest that comes up is Direct Reflectivity, but there is no “Per Light” option that I can see.
Am I looking in the wrong place??? Spent 30min looking for this….
I'm trying to see where some noise in my renders is coming from and I cannot understand how to render these layers “per light” that would help me.
Thanks…
Mantra troubleshooting
2233 2 0-
- firefly9000
- 169 posts
- circusmonkey
- 2624 posts
- firefly9000
- 169 posts
circusmonkey
Hi, see attached. I am using light categories to select what light renders the objects for that image plane .Note I am only using diffuse and relfection, the others I have discarded from rendering as I am not using a volume etc
rob
Thank you so much for the help.
This clarified things
Johnny -
Winter is coming!
