Hi, im trying to create bowl of water where i then drop rock. Now, when i decrease the particle separation to 0.01, the particles starts to disappear, or fall on the bottom of the bowl.
What is causing this? And how can i fix/avoid it? The bowl geometry seems to be solid, or at least there doesn't seem to be any leaks.
Im using Houdini 15.0.416
Cheers
-k
ps: the particle separation is currently set to 0.1 so that the file would open faster. Set it t to 0.01 and simulate to frame 5, look from the side view, switch to wireframe mode and you see what im talking about
Q about disappearing fluid
2359 4 1- KiLa
- 109 posts
- nigelgardiner
- 48 posts
- KiLa
- 109 posts
- nigelgardiner
- 48 posts
- KiLa
- 109 posts
