Can't able to find the import or merge option While impoting
   3843   7   1
trying crowd simulation to add multiple agents
Can't able to find the import or merge option While importing fbx file from maya.
it's a tall popup…
shrink the popup from the top and then drag the whole thing up - the import/merge options are at the very bottom
Training Lead
www.sidefx.com
There is no shrink option for this pop up. we are using windows 10
Cant able to shrink, Sombody help me
Some possible bad workarounds, (since nothing I tried that seemed reasonable worked) :
1) If you have another computer with a higher resolution display, Remote Desktop from that computer to the computer with Houdini. Remote Desktop, (at least the old one; I haven't gotten the new one working), will use the resolution of the computer you're connecting *from*, instead of the one you're connecting *to*.
2) If you have multiple monitors, in the screen resolution settings dialog, drag one display to be above the other and apply that, to get some added height.
3) Install and start up a VNC server that lets you specify a server screen resolution, (I've never actually seen one on Windows, but I haven't looked very hard). Connect a VNC client and scroll to access the whole server screen.
hi
you can use the textport:
in Houdini try:
Windows > HScript Textport
now type:
help fbximport
you'll see the instructions for importing an FBX file
hth
Training Lead
www.sidefx.com
hey Arctor, i tried Hscript textport. While importing it says file does not exit.
I have created a new projects and the placed my fbx file in the projects folder. Still it saying like that. Also I have given the path of the file in Hscript editor, Still it didnt worked, file does not exit.
So please help me where to place my fbx file
Houdini doesn't support backslashes in paths properly. You'll have to use forward slashes instead of backslashes.
